Hi Tulip Team,
We’re planning to use the Tulip dashboard to display Andon/escalation alerts on our production floor monitors. To make the alerts more visible and intuitive, I like to request the ability to apply color-coding based on priority levels.
Specifically -
- High priority alerts** displayed in red
- Medium priority alerts** displayed in yellow
- Low priority alerts** displayed in another basic color (e.g., green or blue)
Could you please let me know if this functionality can be implemented, or if there are existing options to achieve this? I’d be happy to provide more details.
Thanks
If you aren’t able to just utilize an app with aggregations and timer triggers. This is the only way to do this with analytics.
Hey @danielpomeranz,
Yes, I can use the app, but I prefer not to use the player to display the dashboard—it’s not efficient, and also it requires someone to log in manually every day.
Another challenge with the dashboard is that the red marks appear in a very basic table format, which is difficult to read from the shop floor, especially since the TV is mounted 20–25 feet high.
If Tulip can provide a response or solution similar to the example below, it would be extremely helpful.
Thanks
