Bringing this back up as it seems it hasn’t been looked at in a while.
There have been occasions where I have incorporated a button within my application that fires a sequence of triggers and transitions, but then that action of pressing the button gets replaced in the operators process with a barcode scanner or other device.
I haven’t found a way to copy triggers between Widget, Step, and App to be able to quickly change them over in the event I described above. I end up having to manually create each trigger again.
Would be great to have this feature!
