Custom Widget Creation for Administrators
I was wondering if it would be possible to allow Custom Widget creation/development for Administrators.
I’m an admin on our instances, however, I can’t create Custom Widgets.
Hi Jonathan, do you know if your instance is on the “Enterprise” plan or above?
If so, you can use the new “Custom User Roles” feature to expand the access of Custom Widgets to other roles.
+1 to @kevin.kononenko. This is what this would look like in custom user role configuration
More details on this feature are here - https://support.tulip.co/docs/en/how-to-customize-user-roles
@Pete_Hartnett & @Pete_Hartnett I believe we are on the “Enterprise Plan”. I’ll reach out to our Account Owners and see if they’ll make a new role. Thank you.
