Display sequence of tagged variables on Signature Widget
Hello,
I am trying to figure out the display sequence of the variables which is tagged to the signature widget, the ask is that if I have variables named Var1, Var2…Var10 and if I tag all these as Data to Sign with Signature widget, I want these to display in named sequence (sorted) so it makes more sense to the operator while reviewing. For now, it shows in random order though the order remains unchanged even if I add/remove these to the widget to break the order Tulip has picked. It’s not the sequence variables are tagged or created.
Would appreciate any help/guidance offered.
Ashish.
