Donut Chart on Machine Attributes
Hi @gio ,
Previously there was an discussion went on Donut Chart on App Variables, in Similar way can it be done with the Machine Attributes ?
Shashi
hello @psp316r,
once you create a Machine Analysis, if it’s of type One Operation, you can change it’s format to be a Donut Chart:
I will mention that while the above example is displaying the Machine State, you can also customize it to display Machine Attributes.
let us know if you have further questions!!
Hi @gio
Tried for the Compare Variables Analysis, but I can’t see the Donut Chart over there, please refer to the below pic:
Shashi
hello @psp316r,
this functionality is currently only available for One Operation type charts. have you tried converting to this type to see if you can display the information you’d like??
Hi @gio ,
If with Donut Chart is not possible, can it possible by the Bar Chart ?
Can Compare variables Analysis can be done with the Machine Attributes ?
Shashi.
hello @psp316r.
yes, that’s possible. I believe it’s already set to a Bar Chart in the screenshot you’re sharing, is that not what you had in mind??
you can create a new Machine Activity Field, and store the Attribute in the new Field every time it outputs. which can then be accessed in Analytics:
would this work for what you’re building??
Hi @gio
This works, you can close the Ticket !!
Shashi
