Dual-Lingual Options
Hi All!
On our shop floor there are operators using the tulip app created that English isn’t their first language. As a result, they’re having difficulties understanding how to maneuver through the app. Is there an easy solution to accomidate the app for speakers of a different language other than English? For most workers, Spanish is their first language, if that changes it at all.
Thank you for your help!!
hello @txh3467!! that’s a great question, thanks for asking.
one way I’ve seen it done well in the past is by using a Table that contains the translations. if you create a Table similar to this one:
you can then update the text in your app based on language in the Table Record that the user selects:
this is what the resulting app would look like:
is this similar to what you had in mind?? let us know if this makes sense and if you need help building it!!
Thank you so much for that, that was very helpful!!
