Hi all,
A user recently asked how to render multiple STL files on the same step, so I’d like to share a little tip on how to dynamically load STL files from a Tulip Table:
Step 1
Create a table with a “file” data type field named “STL File.” Add a few sample records with files. I found some sample STL files here.
Step 2
Create a new app and add the table + record placeholder.
Step 3
Embed an interactive table with your newly created table as the datasource. Add the necessary fields.
Step 4
Embed a table record widget (Text>Table Record) with the “STL File” field as a record datasource.
Here's what it looks like in action:
