I connected the Zebra printer to the LAN port of the Edge IO and tried to transfer data, but failed.
After some trial and error, I found that I could connect to the printer from the LAN port of the Edge IO via a hub.
I did not change the IP address.
Is there any way to connect without going through the hub?
I will raise this topic again.
Does anyone know?
@maldrich
Thanks for letting me know how to check the IP address.
I will check again.
However, when I tried, I was able to connect through the hub and it didnât work if it was direct.
Is the IP address affecting it?
I am not sure. Did you check that your previous address was of 10.0.5.x?
The IP address was 10.0.5.3 .
@tracy.qiu
Thanks for the info.
I will check the IP address from the edge IO again.
I donât have the Edge IO at hand right now, so I will check it as soon as I receive it.
Thank you very much.
@tracy.qiu
Sorry for the late confirmation.
I finally received the Edge IO.
When I check with Edge IO, I see the following.
Only the item âAPâ is shown.
Is there any way to check?
Hi @tracy.qiu ,
After several Edge IO restarts, âLANâ now appears.
However, it still does not work when triggered from the app.
Do you know what is wrong?
@da-noguchi, unfortunately @tracy.qiuâs co-op at Tulip has ended so sheâs not around to respond to this message, but I want to connect you with @k.ober, who can help you with this question.
Hi @da-noguchi , happy to help.
Sorry that Iâm joining in here late, but Iâm assuming that we have already confirmed that Edge IO is assigned to the station where you are running the trigger. You do have the correct IP address, and have clicked âSaveâ on the page (a mistake I commonly commit).
Your trigger configuration looks correct. However, the âprint textâ function you are sending will only do that; print text. If you want to print ZPL, you must do so with a Template. Regardless, you should be able to print text (for ex., hello world ) with this trigger that I see here.
I recommend two things:
- Change your trigger to simply attempt to print the text âHello Worldâ or similar.
- Open the debug logs with the method below, and send back a screenshot of what happens. In player:
a. Click âDeveloperâ > âToggle Developer Tools (Content)â
b. Click âConsoleâ on the top of the window that appears, if it is not already selected
c. In the bottom of this window, enter$T.Debug.setDebugTriggers(true);and hit Enter. You should have no errors appear in the console.
d. Click the crossed out circle â on the top left of the console.
e. Click your âPrint Labelâ button.
f. Observe what appears in the console, and send a screenshot back here.
Hope this helps! Let me know what you run into.
Hi @John ,@k.ober ,
Thanks for your reply.
I am trying to verify what you taught me, but the âLANâ entry in âDHCP Leasesâ is not showing up again.
Also, Edge IOâs Wi-Fi disconnects happen is often interrupted, so I canât make any progress in verifying it.
Edge IOâs Wi-Fi disconnects happen not only on this device, is it a network issue?
Is there a problem with the device?
Hi @da-noguchi,
hmm, interesting. Can you confirm the following for me?
- Your Edge IO is not pending any software updates (which would be visible on the âEdge Devicesâ screen in your instance)
- There are no cables plugged into the WAN port of your Edge IO
- You have confirmed that the cable plugged into the LAN port of your Edge IO is good, either by testing it somewhere else or substituting a new, known-good cable
Wi-fi disconnects can be a couple of things - if these are all true, then Iâm going to suggest we migrate to Support so that we can pull some logs and see whatâs going on.
Additionally, as a general rule it is always better to use hard-wired internet (if this is available) than wi-fi - I recommend this if itâs nearby.
Hi @k.ober
1-3 all seem to be fine.
3 is not a problem because the printer works from Edge IO through the hub.
I will create a another ticket for Wi-Fi.
Hi @da-noguchi ,
OK, understood. Thanks for checking into this for us.
At this point, I think the best course of action is to contact our Support team so that we can pull debug logs. Can you please open a ticket by emailing support@tulip.co ? Donât feel like you need to re-explain the problem; a link to this thread should be fine. Thanks!
