hi all,
I have an ask from my team to see if Tulip is capable of the below:
Our team sends out contracts in the form of PDFs to clients. these PDFs are modified dependent of the ask. Our team wants to standardize these PDFs where only some areas are able to be edited and can only be edited using specific values(i.e a dropdown list of values) to reduce user error.
Ask: Can tulip modify and save these PDFs(without the step) if a blank template is provided?
I’ve had a look at some previous topics around this and tested it out. I can edit the embed PDF with the variable widgets.
However I noticed that when I embed a PDF, edit it using variables and use a trigger to print, it prints the whole step. Whereas what I’m looking for is to simply save down the embedded PDF. Is this possible?
I also tried importing the customWidget-File Encoder - PDF but i get this error:
Would integrating Tulip with SendGrid achieve the above?
thanks in advance!
