Filedrop/fileshare
Hi All,
We have a usecase where a customer is putting XML files in a specific folder. We can easily pull these files in Tulip with a ‘open link’ and then the URL of the path.
However, we want this to be embedded in Tulip and to not have a link to a notepadd ++ or another file.
Can we create something to mimic the behaviour of this Filedrop like a connector? Or am I missing something in the current connectors to handle this?
Thanks!
Quintijn
Are they local files or on a service like Onedrive or dropbox?
This has yet to be discussed. If there is a solution for dropbox Or Onedrive I’m happy to explore that and propose to the customer.
If it’s on a web-based service, you could possibly use the webpage widget in an app. But the security settings will need to allow for the url to be shared/embedded.
If the file is local, you could use node-red to get the file data as a variable in the app.
Is your goal to just view the data in the xml or use it in part of the workflow/manipulate it?
Should be to only view it, to build some digital workinstructions with the variables in the XML.
NodeRed seems indeed a good solution. Thanks!
I was able to embed an XML file in an app using the webpage widget. We use Onedrive.
Can you elaborate on the solution? The variable/Fixed url you give is the onedrive path?
I tried it quickly and could not seem to get this working.
This is the url you will need from your file in onedrive.
Since we have a unique set of files for each image, i get the UniqueID via a powerautomate flow. That uniqueID is then put into a tulip table and the url input to the webpage widget is built like this.
In our case, the floor users have to have access to the sharepoint folder that the files are in.
Were you able to get a solution that worked for you?
Yes, We’ve figured out a way to make it work.
Thanks!
