Go to Trigger's window from Variables screen
Hi Tulip Team,
Would like to suggest the following enhancement, for applications where we have many variables, and the same variables are being used in different triggers, would be great to access to the specific trigger from the Variables screen, instead of searching the specific button.
Hi @Jian-
We have recently released improvements to the Variables window that I believe does what you are asking. The screen you posted has been updated, are you using an LTS release of Tulip?
Take a look at the GIF below and let us know if this would meet your needs!
trigger navigation
Hi @pete ,
Great!
We are still running LTS 6.2.
But is good to know that once we upgrade feature will be available.
Thanks
