How do I link something in Tulip?
How do I add a link in a Tulip App?
Thanks for your question! You can do this with the ā€œOpen Linkā€ Trigger Action.
Here’s a screenshot:
This will open a link in a new tab in Google Chrome on the computer where the Tulip Player is running.
Hi, what would ā€˜Cannot open url in Bees’ mean?
@hed In the Tulip Desktop Player, there’s a menu called ā€œDeveloperā€. If you open up that menu, is the option ā€œEmulate Query Parameterā€ checked? If so, select it to disable it and the error should go away. Let me know if you have any questions!
great, it works now, thanks!
