can we use wireless barcode scanner which is connected to a tab for getting barcode data into tulip application ? Is there any possibility to read barcode and store the barcode data into tulip application by using wireless barcode scanner which is connected to a tablet ?
Hi @Ajay,
The best way to learn about barcode scanning is to check out the Barcode Unit Test apps in the Library. They provide great examples of how data from a scan will be represented and made accessible in Tulip.
If you need help setting up a scanner, check out this article
