Are you looking to streamline your equipment cleaning processes? If so, then the Tulip App Suite is for you.
This suite of 3 apps is designed to help you digitalize your cleaning operations. Each App builds on top of the previous one, the 1st App being the simplest to adopt.
The apps are:
- Cleaning with PDF Instructions: Quickly digitize equipment cleaning history by uploading existing paper/PDF instructions and tracking completed cleanings.
- Digitized SOP Cleaning Instructions: Replace paper SOPs with interactive, step-by-step digital instructions that automatically record operator actions and timestamps for improved training and detailed audit trails.
- Digitized SOP with Material Consumption Cleaning Instruction: Track, validate, and manage cleaning materials in real-time with digital SOPs, ensuring correct usage, preventing errors, and consolidating inventory data.
The Tulip App Suite is easy to use and can be customized to meet your specific needs. It is also compatible with a variety of equipment, making it a great choice for businesses of all sizes.
Check the support article: Tulip App Suite support article
