Introducing Tulip Lifecycle Manager Lite!
:rocket: Introducing Tulip Lifecycle Manager Lite! :rocket:
We’re excited to announce that the Tulip Lifecycle Manager Lite app suite, developed by FactoryTalk in collaboration with a trusted partner, is now available!
This new solution makes it easier than ever to:
  • Create, review, and approve Tulip apps :writing_hand::white_check_mark:
  • Track app statuses and progress :chart_increasing::eyes:
  • Streamline deployments—all from a single, user-friendly dashboard :desktop_computer::light_bulb:
Whether you’re managing a few apps or large-scale deployments, Lifecycle Manager Lite brings simplicity, transparency, and control to your workflows.
Ready to boost your app management?
:point_right: Explore Tulip Lifecycle Manager Lite in the App Library
Questions or feedback? Drop a comment below and let us know what you think!
Hi gabor,
I received this error when I tried to import the TLM Lite Apps to our instance:
A Tulip Support Ticket #26974 has been raised, but there is still no solution to the issue.
Please help.
Thank you.
Regards,
Edwin Yeoi
Hi Edwin,
Thanks for flagging this and for your patience. I’ve shared your issue with our technical team who are better equipped to dig into these table errors. We’ll keep you updated as soon as we have more information or need any details from your side!
Let me know if you have any other questions in the meantime.
Best,
Gábor
Hey Edwin,
We’re currently investigating the issue and was wondering what release are you using?
Thank you in advance!
Cheers,
Gábor
Hi Gabor,
I am using the following Tulip Version:
Regards,
Edwin Yeo
Hi Edwin,
The issue should now be resolved. Could you please check on your end and let us know if everything is working as expected? Your confirmation will help us make sure things are fully back to normal.
Thanks for your patience!
Best,
Gábor
Dear Gabor,
Everything is working now.
Thank you very much for the support.
Regards,
Edwin Yeo
