We’re excited to announce the 12th release of the Tulip Library!
The Library is a set of apps that can be added to your account and used out of the box. Each App comes with an installation guide and a video describing how the App works and what it can be used for.
If there’s an App in this list that you’d like to use, click on the App’s link below and install it to your account today!
Release 12
The Pick-to-Light app allows end users to scan a part number, pull up the BOM, and light up the correct items using the integrated Pick-to-Light System. Using the app, you can configure the bin size, color and behavior of your light guide system through an intuitive web interface.
Try the Pick to Light app here.
Simple Dynamic Work Instructions(Video) :
The Simple Dynamic Work Instructions app allows you to pull up a task, or any kind of reference material that is linked to a specific product.
