We’re excited to announce the 28th release of the Tulip Library!
If you’d like to use this app, click on the app’s link below and install it to your account today!
Release 28:
The Weigh and Dispense app is a pre-configured application for guiding operators through weighing and dispensing procedures. The app can be expanded to integrate with ERP systems and IIoT to automate procedures for operators, and print container labels while keeping a full audit trail of dispensed materials.
The Zebra Label Printer Unit Tests app makes it easy to test whether or not your Tulip-supported printer is set up and connected correctly.
In addition, this release brings updates to the Tulip UI Template app; an easy way to create user-friendly apps with prebuilt UI templates.
Get started with these apps and more in the Tulip Library.
