We’re excited to announce the most recent release of the Tulip Library.
The Library is a set of apps, app suites, connectors and widgets that can be added to your account and used out of the box. Each app comes with an installation guide and a video describing how the app works, and what the app can be used for.
If you’d like to use any of these apps, click on the app’s link below and install it to your account today!
Release 71:
TLDR: Library Release - r71
Video content:
Aras provides Product Lifecycle Management (PLM) software. Aras integrates with Tulip to provide operations teams with easy access to engineering content on the shop floor. Presented at Operations Calling 2023, this demo shows Tulip and Aras’ integration, which is accomplished via Tulip’s REST API Connector.
In this example, we demonstrated how Onshape can integrate with the Tulip platform. This example shows how to visualize of CAD parts from Onshape and obtain important metadata. Integrating Onshape with Tulip streamlines connectivity between manufacturing and engineering.
Apps:
Simple Checklist Functional Example
The Simple Checklist App makes it easy to build and manage tasks in a checklist. Add images and descriptions to tasks for operators, and track completions and analytics in the dashboard.
Template Mobile Basic - Dark Mode
The Basic Desktop Template (Landscape Dark Mode) is an easy way to get started building standardized apps for desktops. This template contains a single step to start building apps with a clean design. The dark mode template is especially ideal for low light environments to reduce eye strain.
Template Landscape Desktop Basic - Dark Mode
Digital Logbooks replace paper records of standard operating procedure (SOP) to minimize human error. Digital Logbooks digitize records, procedure instructions, checklists, and more, which can be useful for regulated industries like BioTech and Pharma. This application is from the Equipment Logbook University Course.
Apps Suites
This app suite allows you to create new checklists and customize tasks within them, effectively organizing which tasks belong to which checklists. The Checklist Management Suite comprises three applications: the checklist manager app, and two versions of the checklist execution app - one for desktop and one for mobile use.
Connector
The SAP SuccessFactors Connector allows you to connect your Tulip app to Success Factors modules to update activity information and user permission details. This connector connects Learning Management System integration to the shop floor. Implementing SAP SuccessFactors in frontline operations streamlines workforce management, fostering efficiency and agility by providing real-time insights into employee performance, enabling organizations to make data-driven decisions.
Microsoft Dynamics365 Connector
The Microsoft Dynamics Connector enables bi-directional communication between Microsoft Dynamics Finance & Operations and Tulip’s Frontline Operations Platform. This communication ensures seamless data transfer and synchronization. This integration streamlines workflows, enhances operational efficiency, and provides a holistic view of production processes by bridging the gap between back-end enterprise resource planning (ERP) systems and shop floor operations.
Widgets
Image Annotation Custom Widget
The image annotation custom widget is used to easily annotate images stored in Tulip. This widget allows users to mark up images directly within Tulip, facilitating detailed visual instructions, quality inspections, or any process that requires image-based guidance. The Image Annotation Custom Widget enables users to tailor their visual workflows, improving clarity and efficiency in different applications.
If you have any questions feel free to leave a comment. We will get back to you.
