🚀 Logic Blocks are now live in Library
Hey Tulip Community :waving_hand:
We’re excited to announce a brand new asset type in the Library: Logic Blocks.
What are Logic Blocks?
Logic Blocks are portable, production-ready pieces of app logic. Drop them into any app, configure your inputs and outputs, and you’re ready to go. Each one comes fully documented with clear architecture, so you know exactly what’s happening under the hood.
Our first release includes production-ready utilities:
:triangular_ruler: Unit Converters
:1234: Sequential ID Generators
:magnifying_glass_tilted_left: Use Table - Advanced Search
…and more coming
Drop into any app. Configure in minutes. Extend whenever you need to.
Each block is fully documented with clear architecture and ready to use today.
:backhand_index_pointing_right: Go grab them in the Library!
Hello - thank you for the announcement @gabor.miskolci
Are the building blocks developed exclusively by Tulip or is it possible that non-Tulip developers may build them?
Can you comment on whether or not it is anticipated that these building blocks may be validated or use in regulated environments?
Hi Kevin!
You’re welcome to create your own Building Blocks if you’re interested. Our team will review your submission and can help you publish it in the Library, similarly to how we handle partner content today.
Regarding validation and regulated environments, I don’t have more to share on that at the moment, but will follow up when I do.
Cheers
When I went looking I didn’t find anything under building block, but I did find the series under Logic Block: Explore the Library | Tulip
Hello Jason!
Thanks for the noticing, they have been renamed to Logic Blocks indeed. I’ve fixed it in the original post for consistency.
Let me know if you have further questions.
Cheers,
Gábor Miskolci
