Need help with Tulip Table Record Creation
I’m having a little trouble with Tulip and could use some quick help.
I’m trying to create a table record, and I’ve got a column called “Log ID” set up for it. But when I go to create a record using trigger logic, I can’t find the “Log ID” column anywhere.
Am I missing something obvious here? Any tips or tricks would be much appreciated!
Thanks a bunch!
Best,
Mani
Hi Mani,
I think @richardg had this same question just the other week! Does the answer on this thread help you? Using Tables in Triggers that have Place Holders
