Picture External Url
Hello,
I want to insert a picture of my PLM and this is an url called by an API:
Currently, we cannot put it on a picture variable because we have only the option to download a fix one. Is there a workaround to display it on my app?
Thanks
Guillaume
hello @Guillaume, are you familiar with the Webpage Widget?? depending on how the PLM image is presented, this could help with what you’re trying to achieve.
if you could send me your account URL via direct message, I can enable this feature for you!!
