Exciting news - Release 336 is here!
Share your thoughts and questions below
ta-aoki
September 12, 2025, 8:59pm
2
Could you mention in the release note about the saveImage and openFile behavior change when accessing the Network folder?
Tulip is implementing a new site setting in the Account Settings page which will give customers the ability to toggle being able to write to or read from network drives. This new site setting will be implemented starting in r329 and will be enabled such that writing to or opening from network drives is not allowed by default but can be modified. Writing to or opening from local drives will remain enabled regardless of this new setting.
In r336, further implementation of this change will be int…
Hi @ta-aoki ,
We’ve extended out the timeline.
The upcoming change to network drive access will be postponed to r339 and beyond.
As a reminder, this change introduces a new site setting in the Account Settings page that gives you the ability to control whether users can read from or write to network drives. This setting will be enabled by default to disallow access to network drives, which is our recommended security posture. Access to local drives will remain unaffected.
We originally communicated that this new setting would be introduced…
Sincerely,
Jake
