after a discussion with our quality management it is very import to pre-set the output name when printing our QM protocols as PDF.
I know that you call the system printing dialog, but the pre-set file name is at the moment “Tulip_Player”. So all employee have to change this to the given correct file name.
Is it possible? Within Windows it is possible with an API call parameter.
Regards
Chris
