These are the product updates in release 206.
Release 206 will be available for some customers on 05/10/2021 and will be live to all production customers on 05/16/2021.
Improvements and Features:
- Added support for interval and timestamp comparisons in Expression Editor
- Timestamps are allowed as the x-axis in analyses
- Expression Editor shows all suggestions when inside a function
- Aligned order of selecting ID then record placeholder for loading table records
- Both downloadable Player and browser links for Shareable Stations are now shown
- Input field components in table record modals have been updated
- New items in the news feed show up on top
- Library is now linked in the App Editor
- An endpoint has been added for increment/decrement of table record columns in Tables API
- Machine triggers can now use machine variables
Bug Fixes:
- Enabled state change triggers for machine types
- Links in admin tables page now link properly
- Expressions in Analytics Editor do not overflow, which was preventing deletion of an operation
- Enabled editing of an analysis using machine types with custom activity fields that are colors
- Users cannot create a placeholder that does not link to a valid Tulip Table
- Account owners can see the user table with custom fields
- “Last Machine Output” always gets the correct value
- False error messages on logout no longer occur
- Documents can be embedded in GovCloud instances
- Table record paths properly escape
- DATE_TRUNC_TZ expression properly incorporates timezone
- Machine attributes widget always display the value, even if it is not mapped on the machine type for the machine
