These are the product updates in release 214 of the Tulip platform.
Release 214 will be available for some customers on 09/23/2021 and will be live to all production customers the following week.
Increased Barcode Support:
In the Barcode Widget, you can now generate more types of barcodes including:
- EAN-8
- EAN-13
- CODE 39
- CODE 128
- ITF
- QR Code
Onboarding Flow:
We’ve added a new user onboarding flow when someone creates and logs into their Tulip account for the first time
Improvements and Bug Fixes:
- App completion performance has been improved
- “Empty State” styling for inputs has been unified across the platform
- Unique values aggregation results can be used on the Tables page
- Selecting empty strings in Schedules does not cause an error
- Schedule changes in Asia are not offset by a day
- Double-clicking the interactive table widget does not freeze the App Editor
- Users can create expressions of arbitrary length (no longer limited to 150 elements)
- Customers can reregister the same device with Shareable Station links
- Videos will play with audio on Safari browsers
- Linked IDs show up in the correct link field in the Record History Widget
- An issue preventing specific stations from storing completion data has been resolved
- Tulip Player registration page will always give the option to assign to an existing station
- Saving expressions does not remove brackets
- Apps will export if a widget gets resized
- An issue with removing Table record placeholders in the App Editor has been resolved
- The machine creation modal has an updated design
- The machine edit state will no longer persist when navigating to another machine
