Single Select Trigger Issue (r275.3)
There seems to be an issue with the Single Select widget triggers in the latest release. (r275.3)
All Single Select Trigger “When” conditions have been erased and the dropdown menu selections are missing, there is only “enter key is pressed” within the menu.
This will break all triggers, but they will run like normal if the “enter key is pressed” option is selected.
I am curious if anyone else is experiencing this issue, and if changing the “When” condition to “enter key is pressed” will break the trigger again once this issue is resolved?
Hi Kellen,
Thank you for pointing this out. The Tulip Team is aware of the issue and working to address it in the next release (and it will be included in LTS12 as well).
If anyone else is having this issue feel free to chime in on this thread!
Closing this thread because the fix went out in r277 / LTS 12!
