in our production site we have different use cases like tablets which are used by multiple user accounts (which needs a automatic Timeout set) and we have devices where a machine user should be logged in all the times.
Enabling setting station timeout options individual for certain stations would be a great feature to have!
I’ve also come across a scenario wherein it would be valuable to bypass the automatic timeout/logout depending on the app being run, regardless of station.
This might also need to be restricted based on the user (e.g. only supervisor or superuser), but that could be managed with user permissions for the relevant app.
Has there been any progress on this? Setting timeouts by station (or station groups) would be incredibly useful for us when deploying things like dedicated dashboard stations/apps. The timeout makes these scenarios functionally impossible at the moment.
There are no current plans to have timeouts by station or station group at this point in time. We will look to pick up this work in the coming months if we have bandwidth.
This is quite disappointing, to put it mildly. Without this (or a substantially similar functionality), none of your GxP customers that require automatic user timeout for compliance are able to build functional dashboard apps. The browser based dashboard functionality is extremely limited, and is not an adequate substitute for dashboard apps in Tulip’s current state.
The only potential way around the limitation, as far as I can see, is to use a mouse jiggler or similar - which is going to violate most corporate infosec policies.
What is the relative prioritization of this issue at this point, from Tulip’s perspective?
Still a big need on our side too — shared tablets vs. dedicated stations require very different timeout behaviors. A single global setting creates real issues. Configurable timeouts by station/station group would make deployments much smoother. Any update if this is on the roadmap?
Understood, this is helpful for us to understand. We can look to add it to the roadmap but there are a few key considerations here:
Is it acceptable to only have this on the station group level? My main concern is that station by station configuration becomes incredibly difficult to maintain/set up.
Is the core target by app? Device type? Station group? Understanding the intent would allow us to focus and scope this down.
Station Group level would work best for our purposes, as timeout exceptions are generally going to apply to classes of station (e.g. stations that are used exclusively for Dashboards). If we ever had a one-off scenario, it would be acceptable to set up a dedicated station group to cover it.
I agree - station by station is a little too granular to manage at scale, and would be prone to error.
Hi @jakerigos We are currently experiencing significant challenges displaying dashboards on the manufacturing shop floor due to session timeouts. As Dan previously mentioned, it would be extremely beneficial if this setting could be configured at the station group level, allowing sites to adjust it based on their operational needs.
Any update on the feasibility or timeline for this enhancement would be greatly appreciated.
Hi @criszamora28, thanks for bumping this. I’ve taken over Stations and Player from Jake, so I’m picking things up from here.
We don’t have a fix for this lined up just yet, but we’re actively discussing a path forward. One question that would really help - if the timeout could be set per station (or per interface) instead of per station group, would that work for your dashboard screens? @Dan, same question for you, since you brought up the station group case earlier.
Hi @atrabuco That could work for us, but it would require a significant amount of manual assignment for every station. However, if that is the only short-term solution available, it could still be a viable workaround for our needs.
Thanks @criszamora28, that’s helpful. To clarify what I had in mind: the account-wide timeout would stay as the default, and you’d only set an override on the stations that need one, like your dashboard screens, so you wouldn’t have to touch every station.
For anyone following this thread - if your sites have more than a handful of screens that need a different timeout, I’d like to hear about it. That’s what would tell us whether station group is worth building on top.
