Trigger conditions comments
When defining a condition, trying to implement a bit complexed scenario(Multi-level), one will get some nested structure, with few levels of .
In such a case, it is not trivial to isolate the needed level in order to change or fix configuration’s behavior. You will probably have to follow the full logic ladder.
I would consider to enable the citizen-developer add a comment near the condition, hence make it easier to understand the structure later or by other developer.
Thanks for your attention.
HI @shaysc -
Welcome to Tulip Community and thank you for the suggestion! If I am understanding your request here, you are interested in having the ability to comment in triggers to make it easier for citizen developers to understand the logic, correct?
We actually already have an open product suggestion for this here: Quality of life: Comments in triggers
I encourage you to go ahead and vote on that suggestion and I will link this thread to that one and make our product team aware of your request as well :slight_smile:
@shaysc good news on this, commenting in triggers is now possible with Release 298 - December 2024 :tada:
