It would be nice to have a delete icon to go with the cut and copy icons on triggers.
The current process of having to hit “edit” then wait for the editor window to load, then hit delete can be time consuming if you’re deleting multiple triggers or have triggers with a lot of logic in them.
This is a great idea @richard.vaughn -
I have run into this too, especially when you need to kill a dozen triggers this is tedious.
Let me write a ticket for this!
A little trick came up in internal discussion -
Using the scissors icon next to each trigger will effectively do the same thing as a delete button. We will still go down the road of a dedicated button, but this works for the interum.
Huh, yeah, that makes sense. Didn’t really think of just cutting them out.
Thanks!
