Tulip machine tags features How to Send Data to Machines from Edge Devices using Node-RED and Tulip Tags | Tulip Knowledge Base - Support for Building Operations Apps is a great feature on the “edge-driven” journey. Some feedback about the first version.
- The use of a single tag list is quite restrictive. Indeed, if several devices are connected to a gateway, the tag list corresponds to the concatenation of the tags of several devices. Having a tag list by equipment seems to me simpler because in the end users want to connect an equipment not a gateway
- When you have a machine with hundreds of tags the creation of the tag list is a bit painful. Be able to create the tag list via a node property that can be driven by the message (msg.payload…) can be great.
- I’m looking forward to the OS51 version to send data in multiple tags.
