As you start building apps with Tulip, you’ll notice there are a lot of tips and tricks to help you build faster and more efficiently.
Below are some great tips that have been posted by the Community for you to check out!
Tips and Tricks for Building Tulip Apps - @danielpomeranz (with some additional tips posted in the comments from @thorsten.langner, @David2, @k.ober)
Better Tab Names - Chrome Tab Modifier - This tip from @Pete_Hartnett is helpful if you often have many tabs open in Chrome with different Tulip tables, apps, or connectors and want the names to reflect what is what!
Quick tips - Autoincrement table records - When updating table records, you may want to auto-increment the record ID instead of using a random string. This video from @freedman shows you how!
Using Values In One Single Select Menu to Dynamically Populate Values in a Second Single Select Menu (Part 1) & Using Values in One Single Select to Populate Values in A Second Single Select Menu (Part 2: Tulip API) If you are looking to use values from one single select to dynamically populate values in another single select, there are 2 neat ways to do this, both demonstrated in these threads from @John
Looping can be really helpful if you need to go through a table and bulk update records (such as a status of work orders) and there are 2 main ways to accomplish looping:
- For non-GXP Tulip users, there is a custom looping widget in the Tulip library that is great to use and is explained more in this thread Looping in Tulip Apps just got EASY by @Pete_Hartnett
- For GXP Tulip users, we advise not using any custom code due to validation requirements, so instead you can use step looping as demonstrated in this thread Quick tips - Looping! by @freedman
The Tulip Library also has a collection of quick tips here https://tulip.co/library-search/?content-type=quick-tips. that cover a variety of topics, so check that out!
