Hello, if I set up just a monitor am I able to use a Tulip I/O gateway to run Tulip player? Or do I need a computer?
Thanks!
Thanks!
Hey @eric.byers -
The IO gateway cannot run Tulip Player, but Edge IO can.
Important to know - These devices have ~1/4 the computing power of a modern desktop machine, and app performance often scales roughly linearly across this vector. Many applications that are heavily table-driven will feel slow, but many other use cases (dashboards, static work instructions, data entry, etc) are running out in the field.
