I noticed that if I use the “When: Timer Fires” background app trigger, the minimum allowed time is 30 seconds. We have had several instances in which we wanted to use a smaller timer cycle, e.g. 1 second or 5 seconds, and it seems strange that this isn’t supported. Can we remove the seemingly arbitrary minimum of 30 seconds from this feature?
Hello, @Dylan;
I suggest to reach out to TULIP support with your actual use case.
They can possibly unlock other Timers for your instance.
It would be questionable to allow extremly short timers for everyone by default.
