Wirelessly connected Edge MC devices
Hello,
We have multiple Edge MC devices that are connected wirelessly and found the connectivity to the network to be problematic.
Our wired devices are much more consistent. Are there certain models, certain antennas, or even certain settings that would improve the connectivity?
Thank you.
Gerry
Hi @gerry.dewil and welcome to Tulip Community! :tulip:
I checked with the team on this one, and it seems the consensus is that connecting Edge MC directly to the ethernet is going to be most reliable.
You could get a router and run ethernet from it to the Edge MC as an option.
If wifi is you only option (or preferred option), Edge IO wifi in general is better than Edge MC.
Does this help?
Beth,
Thank you for your reply.
This does help. We are converting to wired connection where possible and will test the Edge IO where wifi is needed.
Gerry
