Attempting to Scan Barcodes With Camera
Hello,
I reviewed this knowledge base article:
It says to select Barcode Camera under your Camera button… what if you do not see that and only see Vision Camera?
Does this mean the camera I am trying to use doesn’t support barcodes?
Hi Ashley,
You should now be able to see this feature now!
Could you please check and confirm if you are seeing it?
Het.
Good morning Het,
Unfortunately I am not seeing it, I’m only seeing the Vision Camera option.
Hi Ashley,
Can you test again and confirm, please?
Het.
Hey Het,
It’s working now, thank you!
