Camera Resolution
I have a webcam that can take a picture with a resolution of 2364x2448. When using the image input widget, the image captured is 1280x881. I understand with vision I can have super high res images, but we’re just looking to capture a high quality image that won’t be used for AI purposes.
The use case is we need to take a high quality picture of various labels before they are applied to an instrument. The image must contain the actual labels being applied. We would like to retain a copy of the labels prior to applying them. We’re currently using a copier for this task, but I think we can get something better using the image input widget.
Is there any way to increase the resolution?
I’m going to bump my own post with info I found:
It seems in R262 the resolution was bumped. We’re using LTS 13.2, so I believe we should be on the new resolution. I may put in a support ticket after updating the team shortly…
When in doubt: Search the forums!
I’m not sure why this wasn’t higher on the list, but this topic answers the question (the bump in resolution isn’t by default, you need to ask for it)
I’m not sure what the actual new resolution is (width and height) but our camera is a 8MP camera with a image resolution of 3264x2448 (4:3) so hopefully we will be able to upload high quality images?!? I’ll close this now.
