Downloading older Tulip Player versions?
We have a use case question about the need to roll back to a previous version of the Tulip Player. For example: Validation is written to a specific version of the Tulip Player, however a newer version of the Tulip player has been made available.
At the same time, the AUTOUPDATEENABLED is set to True, enabling updates. A machine could launch the tulip player and the player updates to a version higher than what’s allowed in the validation documentation.
If this were to occur, is there a site or repository with a list of older versions to download?
Hey Jason!
2 things here:
  1. To disable the auto updates to prevent this, you can follow the guidance here: How to Disable Automatic Updates for the Tulip Player
  2. To be able to download a pervious version in the case that an update has gone through that you aren’t ready for, you can do the following:
Replace the x.y.z with the specific version in the following links:
Desktop Player
Mobile Player
Awesome, thanks Beth! This will be helpful in the future as a “Just in case”
