Hi all,
hoping I’m at the correct place for our problem…
We are using a Edge MC for our barcode printer, what worked fine up to a network error (blackout).
Now we can’t connect to the surface of the Edge: ERR_CONNECTION_REFUSED
But I can see the device is up and running, I did an update of the firmware via dashboard, but the barcode printer and I can’t connect to the device. The IP range is ok .
What can I do without resetting the device (and loosing all the barcode templates)?
Hi Alex,
thanks for your answer.
Printer reset makes no changes.
The IP of EMC and Printer haven’t changes, but I can not check the printer IP inside the EMC cause I have no access to the EMC surface (see title).
I guess I have to reset the EMC by our technicians
