I have a product and I want user to create its BOM. How can I do this? The number of BOMs inside a product can vary. I need them to be changeable later on, in order to any wrong input. Example
Product 1 - a - b - c Product 2 - d - e - f -g
Hi @OzanB, this is a great question. This is a great use-case for Tulip Tables. I would recommend checking out this course in Tulip University.
If you want an example of BOMs in Tulip in action, you can download this library application.
