I am trying to connect my DMG MORI machine with IOT to the tulip for machine monitoring.
my laptop is connected to the IOT.
Then I created the machine data source.
I am getting connection time out during the test.
can you help
The solution here is probably going to be configuration specific, can you please email support@tulip.co
Thank you
Later we purchased the Edge I/O, using the same I could able to connect the machine.
I am able to read in all signals from the machine.
I’m glad this worked. Please let us know if there’s more you need help with!
