Release 197 - December 2020
These are the product updates in release 197.
Release 197 goes live to all production customers on 12/13/2020.
Bug Fixes
  • Transitioning in a step open trigger no longer drops remaining step open triggers
  • UI is no longer hidden when searching for tables with special characters
  • Connectors can now run with no user
  • Multiple CA certificates are allowed in LDAP configurations
  • App imports including tables with table links have been fixed
  • Missing options in Machine Analysis Builder have been restored
  • A bug with audit data for record creation has been fixed
  • Hover information for embedded analysis widgets has been improved
Can you explain this point?
Thank you
Hi Youri,
This addresses a bug that was causing connectors to fail if there’s a connector function that is set to execute after log out. Now connectors can run without a logged-in user.
Let me know if that helps!
Thanks for clarification
