These are the product updates in release 207.
Release 207 will be available for some customers on 05/19/2021 and will be live to all production customers on 05/23/2021.
Improvements and Features:
- Unusable options are removed in machine-related app triggers
- Archived apps modal has been updated and has proper verbiage
- Machine variables can be used for “Last Machine Output” data sources
- Ensured exporting a connector does not include sensitive secrets and tokens
- Added the ability to set the number of decimal places in the Machine Status Widget
- The error page placeholder has been updated
- Improved formatting for long text in the Record History Widget
- Connectors handle cases where OAuth 2.0 refresh tokens expire
Player 1.0.1 Improvements and Bug Fixes:
- Proxy credentials no longer open when not required
- Fixed permission issue with Camera on Mac
- Added Chinese, Japanese and Polish translations
- Improved OPC UA support
Bug Fixes:
- Activity fields can be added for machine status widget
- Gateways will no longer falsely show up as deleted
- Fixed an issue blocking imported analyses from running
- Machine activity table updates in real-time
- Switching between editing multiple select inputs always updates options
- When showing table record details in Completions, archived columns are hidden
- Table records are displayed correctly in Completions in Dev Mode.
- A check of every usage option occurs before deleting a machine attribute
- All options can be selected when creating machine activity fields and attributes
- Analytics editor functions properly when using machines with custom color activity fields
- The client secret does not get overwritten when editing other parts of a connector configuration
- Analyses can run on multiple machines even if the types have different custom activity fields
