Release 279 - May 2024
Hello everyone
I’m excited to introduce Release 279! This release includes updates to Automations and the App Editor, as well as several UI improvements across the platform. Here are some features worth highlighting:
  • Rename a logic block in an automation in the logic editor
  • A redesigned context pane in the app editor that adds Overflow Styling
  • View Last Published relative dates for apps in tables
  • Set the decimal precision for numeric fields in Universal Template analyses
There are also some performance improvements and bug fixes that were reported by users.
View the full 279 Release Notes here.
Let us know your thoughts and questions below!
Lianna
Woot woot!! :tada:
@Richard-SNN’s request Fix support request silliness was addressed in this release, and now support requests open in a new tab to improve user experience.
@ChrisF reported a bug here Bug r276.2: can't copy code from connector that was also fixed int his release!
Two of my favorite features in this release:
  1. When importing apps from the Library, there is an added descriptive message in the Import modal telling you if an asset is incompatible with yourTulip version.
  2. In automations, you can now undo/redo the creation of logic blocks using buttons at the top of the editor or by using the keyboard shortcuts for undo(cmd/ctrl-z) and redo(cmd/ctrl-shift-z). I know there is a lot of desire for this in app editor as well (and we hear you!) but I wanted to call this out as a small win while you wait for that functionality in app editor too :slight_smile:
