Release 291 - October 2024
Hello everyone,
I’m excited to introduce Release 291! This release brings updates to several features, here are some of the highlights:
  • In the app editor, “User Groups” are now available as a new Tulip data type within variables.
  • Added a new permission for editing the production environment of connectors used in published apps or automations. Previously this was not available, and now the following existing roles should get this access: Account owner, Workspace Owner, Sysadmin, Connector Supervisor. When creating a new role this is not selected by default.
  • Added more granular filtering in Automations with a new option to only run when the specified fields in a table record have changed.
There are also multiple bug fixes throughout the platform included in this release.
View full release notes here .
Let us know your thoughts and questions below :arrow_down: :blush:
Fanni
This release addressed @carlin’s question and suggestion Double Emails from Automations Trigger :tada:
Woohoo! Thanks Tulip team :blush:
@jaksif
On the app editor page, the step timer widget will now have an updated context pane, similar to input, button, text, and variable widgets.
Please could you explain what this is? I do not know what the “updated context pane” is. Maybe a screenshot will help.
@jaksif
PLAT-38037 Fixes an issue where app cancellations weren’t firing in certain scenarios that involved closing Player while running an app in validation mode.
Please also let me know what the “validation mode” is.
I saw PLAT-37773 and PLAT-37754 in r290 release note. Why is it on r291 again?
The right hand panel for the widget settings (where you set the source variable, the color, dimensions…) is now updated to the newer design as the other widgets…
Hi @ta-aoki
Thanks for this notice, checked and this is also a duplicate by mistake, which is now corrected.
PLAT-37773 and PLAT-37754 were introduced with Release 290.
Regarding validation mode, this is used for GxP customers, you can read more details in this article.
Regards,
Fanni
