Slack Custom Widget - Post to Slack with Incoming Webhooks
Want to send a message from Tulip to a Slack channel. This widget allows you to quickly set that up using the “incoming web hook” functionality in Slack.
Screen Recording 2022-09-26 at 9.50.21 PM
Alert a group of people when an issue occurs or when a process is ready for the next step in the workflow using this widget and Slack.
The widget simplifies Tulip to Slack channel connection by avoiding the need to create a correctly formatted connector function that then has to be added to an app trigger. With this widget just add it to the app, provide the “incoming web hook” url, subject, text and you are ready to post to a Slack channel.
Posting a message to a Slack channel helps bring visibility to a problem or alert an individual(s) of an action in a workflow. Further automation or logic can be added to Slack to facilitate more complicated workflows or actions.
Slack is a communication tool that can be accessed from many different device types and a range to team members. The main advantage of Slack is the concept of channels that allow multiple users to communicate in one common place. With Slack channels, you can stop worrying about maintaining a distribution list in Tulip or assigning a backup user in the event of user vacation.
Start posting to Slack to increase better communication and collaboration within your team!
Download from Tulip Library: Coming Soon
parthmparmar@gmail.com – GitHub – LinkedIn
Link to Setup Guide: Link
@EddyA and @eddy.atkins → Slack Custom Widget Post
