Step duplication
Hello,
Would it possible to add a feature in the app editor where an entire step (UX/UI, triggers, etc.) can be copy/pasted from one app to another?
Best,
Kevin
Hey @kkl -
From the app overview, if you right click on a step name, then paste into the step list of another app, the triggers, tables, widgets etc will all be copied.
Hope this helps-
Given that this is possible currently with the step from Pete above, I am going to close this. thread as resolved!
