Currently each time we want to use a Gateways into another instance, for testing, validations or developing, a factory reset is needed to register the device under the desired instance.
It will be great to have like a switch option to change the instance directly from the device
Hey @emendoza, this is actually already possible on the latest OS version if your devices are up to date!
You should be able to change Tulip account from the device portal:
Let us know if you have any problems here.
Hi Gio,
I see this option enabled for EDGE IO devices only, what about IO Gateways?
Any plan to add this feature?
Hi @emendoza,
Ah! For I/O Gateways (and Edge devices) you can also navigate to 10.0.3.1/setup (or /setup for the device’s IP address). This should allow you to also re-register the device!
