To read static value/data (no change value, String) from connector ( Kepware )
Hi, I’ve been working on testing “connector” which is reading data from Kepware server to Tulip instance for machine related app.
After I configured the field mapping , once the data is changing, I can see the value in Tulip successfully, but it seems not possible to see the static value that rarely changed, or string value which is a label of something, in PLC program, and in Kepware too.
Is it really not possible to read and show this kind of data in Tulip? How do you tackle this?
For those who has the same issue, the problem is solved by enabling feature for this specific reason when loading static data with help of Tulip. It is like a check box at side of each data line that you get from other platform(Kepware). You can contact Tulip for help, if you don’t have this feature in your instance.
