Hey Tulip,
There’s an issue when importing apps across different servers (instances). I think it’s a bug that might have gone undetected.
If I have triggers attached to an embedded image, those triggers show up as deleted triggers after importing.
The image migrates correctly, but all triggers get lost/deleted.
Thank you in advance for looking into this!
Eric Singer
Kailey
January 26, 2021, 5:34pm
2
Hi Eric,
Thanks for reporting this bug. I have passed this along to our Platform team.
I will update this thread when we have an estimate of when it will be addressed.
Kailey
Hey Kailey,
Any update on this bug fix. I have an app that I’m afraid to import to another instance until the bug is fixed because there are a lot of triggers on embedded images for this particular app.
Can you just let me know if you have any update?
Kailey
February 19, 2021, 4:29pm
4
Hey Eric,
This was bug was fixed in r201, which went out to the production release group last night (2/18).
You should be able to import without worry now
Best,
Kailey
