Is it planned to allow file upload from the “Input Camera” widget in a normal step as it is possible from a Step Form with Photo widget? Thanks
Hey Youri, we definitely want to include all the functionality in Form Steps within normal input widgets. So this is a great example of that!
I don’t have a timeline for you at the moment, but the general goal is to move away from Form Steps and move all those features into normal steps over time.
@youri.regnaud this came out recently and I was able to significantly reduce logic and steps within my apps. Flagging in case you missed it - and most of all, thanks for the suggestion!
indeed, thanks @youri.regnaud for suggesting this!!
as of Release 209: Release 209 - June 2021, it is possible to upload images in Image Widgets used on regular Steps.
